You will need to check peak bitrates, not average, as it’s the peak bitrates that shoot up and bottle-neck 100Mbs Ethernet links. Average bitrates (and file sizes divided by durations) don’t tell the whole story of a video file in bitrate terms.
This is a graph of Blade Runner 2049 - peaking at >120Mbs with quite a few >100Mbs
Using scp on S905x2 (not direct dump of network stats) i have stable 89,6Mibps, nothing more.
Worth mentioning is MTU, we stream big files so we have almost all the time packet size like 1500, so the transfer should be stable.
I streamed 4K version of this from BD and didn’t have any problems, possible explanation is that kodi use 20MB cache so I’m safe for 2 second burst(80Mibps traffic + 10MB from cache per second).
@CE Team, do you change default kodi cache values for CE installation?
Yes - a lot of people use ‘stream’ to mean ‘play over the network’ - not to differentiate between a server-side streaming application instead of using a regular file server. A lot of people will use NFS or SMB/CIFS servers and so won’t be streaming.
