Anyone got CE working on the HAKO Pro (S905Y4-B). I don’t have but I just know the chipset is supported.
Another question, if a chipset is supported, does that mean that WiFi + BT are also supported?
The device looks Google certificated, so I guess no. The SoC is supported, yes.
CE booting does not mean WiFi + BT is working, no.
Does Google certified mean CE working is unlikely?
