Hard reset
Hello
I wanted to reset CoreELEC to factory settings
I made har and soft, everything remained unchanged
all skins, addons, passwords, shh, nothing happens
If you want a clean start I would advise you to make a fresh install.
ok thanks bro
Another option is to SSH to your device and do rm -rf /storage/.*; reboot
this is what I do, but I thought that in coreelec options it can be done without any additional commands
but there is no problem, it is not done on a daily basis
I have another question
Netflix:
Live TV:
How to set the decoding to be Hardware and not Software
On netflix I have SOFTWARE and it works fine but the processor has 75% to 100% and the temperature reaches 65 degrees
on live tv I have HARDWARE and it works stably there are no huge jumps on the processor and there are stable temperatures
my box is gtmini-a
Netflix is software decoded. That’s the only way in kodi.
understand,thx
