Hey Portisch!
just installed current 06022021 nightly of CE 19.
Will test CEC here. I had it disabled completely for last two weeks because this bug occured and then i decided to use only original IR Remote. I will give feedback.
Action: power on TV HDMI 1 → CEC works.
And now: when DVB-C source is selected in TV and then back to HDMI 1 → CEC is lost.
Did not have such result in configuration:
N2 → AVR (HDMI in Media player) / (HDMI out ARC) → TV (HDMI ARC)`
In that configuration switching source in TV back and forth from DVB-C to N2 CEC usually was working .
Now I need to send CEC Activate command using Yatse in order to make CEC back working when switched back from TV DVB-C to N2.
I changed my setup because AVR is the old model that is not capable to receive 4K Video.
I see you have been testing some new CEC implementation which I hope might also solve my issue, so my question is: will it be implemented in next CE 9.2.5 version or only in next version with Kodi Matrix?
If you’re not already using nightlies, you should do it, either Leia or Matrix. Because if you don’t test the changes and you still have a problem, that one is not going to be fixed
