This system has worked like a charm for years, and I only use it to host my Kodi living room installation.
As of some weeks ago, the HDMI port was able to produce video output, but the sound was gone. All I could hear was some soft scratching noises. Then I went off on a trip.
Today I tried using Kodi, and all I get is a white screen (and no sound still). The ODroid box is up and running, and I can ssh into it – this is how I checked the dmesg output.
Can anybody provide any hints? Is this some well-known issue? Should I upgrade something? Is it toast?
Not very strongly protected interface. I had one die on me when the plug on the TV was put under pressure. Very likely irrecoverable. I use mine as a headless Homeassistant server now.
Same for the usb3 hub. I have to use the usb2 OTG on some to keep devices from interfering with each other. Other than that I think they are really nice
Thank you everyone for the answers, unwelcome as they are
What is a current, up to date suggestion for a new replacement box that is similar to this one? All I do is run Kodi on it, showing movies and shows from my NAS. No TV, (almost) no streaming.
I think getting another one of those devices wouldn’t be a bad idea. Other than that, you can get the device I have ATM the HK1 RBOX R1 (or any of their clones) 4GB RAM 64 GB HDD. Just replace the dodgy android firmware with CE on the emmc and you should be fine
I would be inclined to stick with a N2+. I got my last ones from a German reseller for about half price -they probably were part of a crypto farm but they have been running faultlessly for over a year at this stage.
The alternative to consider is to go for a N100 based mini-pc. Intel are now generally capable of everything you need in a media-player, are economical to run, and because they run a mainline Linux kernel they are generally more stable in use. You can run Libreelec instead of Coreelec for a roughly comparable user experience.
Quick update, to bring closure to this topic. It was not the ODROID, it was the receiver. I managed to test everything a bit more systematically, and my Kodi box is still working like a charm!
Bad news is, now I have to fix / replace the receiver. Perhaps I will just exchange it for a soundbar. Which will be quite the conceptual jump for me, because right now I have some seven devices plugged into the receiver (most of them through HDMI), and a single HDMI cable from the receiver to the TV, but it seems this is not the way it is done with soundbars, where you are supposed to just plug everything directly into the TV, and use ARC / eARC to send the sound from the TV to the receiver? Still learning this stuff…
Thanks for the update.
I think you’d much rather have the HDMI port of the n2 broken :-/
Coincidentally, looking for an alternative for my audio setup myself (currently a budget soundbar using eARC).
Good luck finding a nice alternative …
