Help ''Player Debug Info'' Key Editing, Picture added inside!
thanks i will give a try
Hi everyone. I’m having this same problem with my Minix Neo A2 remote and tried with both the file that @boot2k3 attached and also editing the keymaps.xml file with Notepad++ with the keyid of Z that @kostaman advised but it doesn’t work. I’m using the latest Plex add on for Kodi and running latest CE 9.2.1
Other keys like O to bring up player process info and I to display information of the file works, but pressing Z does nothing. The O and I work out of the box without needing to configure any key map, but because Ctrl is not available on the keyboard I can’t do that. Any help is greatly appreciated. Thank you.
hi blizz follow my steps , i have done it correct.
Hi tunii. Your step is to use the file @boot2k3 attached right? It doesn’t seem to work. However, I discovered something. It works in the Kodi videos but doesn’t work in Plex add-on. Is there any way to make it work on plex as well?
