HDR
#1
I’ve just received my Odroid N2+ which came with Android installed on the eMMC. I’ve installed 9.2.3.95 on and SD and booted from it successfully.
I want Coreelec to be moved from the SD to the eMMC and Android totally wiped but when I run ceemmc -x I get the following error.
eMMC size: 0x0003a3e00000 [16GB]
Partition ‘/dev/reserved’ does not exist!
Failed to read original partition table!
Can anyone help?
Wrong command, You have to use installtoemmc for N2
HDR
#3
Thanks for the quick reply.
I get the following if I try installtoemmc
This script is only for Odroid N2. It won’t work on other devices!
Odroid N2+ is very new, maybe the script must be modified by the devs
Other option You can install CE directly to eMMc module using USB-eMMc adapter
HDR
#5
I knew I should’ve got a USB-eMMC adaptor with my N2+.
Thanks for your help, I’ll post over at the N2+ thread.
HDR
#6
installtoemmc now works on the N2+ with 9.2.4
system
closed
#7
