Hi all,
I have an Odroid N2 and I want a keyboard shortcut that will shutdown this device. I know ‘S’ will bring up the Shutdown Menu, but that is not what I’m after. I want a shortcut that will just shutdown the device.
TIA
Greg
Hi all,
TIA
Greg
In your remote.xml or keyboard.xml you can map a key with the Shutdown action.
For example:
<s mod="shift">ShutDown()</s>
To use Shift + s key.
OK, will give that a try.
Thanks.
Yep, that does work. Thank you.
Question:
What is the difference between this:
and this:
<s mod="shift">ShutDown</s>
TIA
Probably no differences.
