I am trying to get the display to work on my device. I installed the OpenVFD Service and tried a few different VFD.conf files, but none have worked. Can anyone help with how I can create my own custom config?
Looks like your box is using the HBS658 controller. I had not have a chance to test this one yet, but it should hopefully work. If it doesn’t work, reboot the box, and post a dmesg log, like so: dmesg | paste, then copy the URL the command returns.
Try using this vfd.conf: https://github.com/arthur-liberman/vfd-configurations/blob/master/m9-pro-vfd.conf
You can do that with this driver + script.
Extract it in downloads folder, then use sh test_led.sh to rerun the driver or sh stop_service.sh to disable it.
Hey! I know this is kinda old, but I’ve a similar issue. Used your tool to load the latest m9-pro-u2c-x-u5x-s-vfd.conf, but I can’t get it to work. I’ve a U2C Z Pro (2/8GB, S905X):
Update: I found a dtb.img similar to my device. Someone over here contacted the official u2c seller on amazon and got the official update file, containing the dtb.img. I’ll contact them, since mine is a U2C Z Pro, not U2C X Super, but the display look exactly the same (without BT).
What’s not working? Is there nothing on the display or is it messed up?
You can probably extract the DTB from your box yourself. You need to boot into Android for it:
You don’t need to change DTB files. Stick to the DTB file that works for your box in the device_trees folder on the SD card.
I’ll look at the Android DTB to see if it has the configuration for the VFD.
Great! Do all the digits and icons work and are they in the correct positions?
To decompile a DTB file I use the following command (you need to install dtc) dtc -O dts -I dtb -o filename.dtb filename.dts
Edit: The DTB file you posted is a multi-dtb file. I had to open it with a hex editor, and cut out just a single DTB file from it. It usually starts at address 0x0800, and then you cut it off after a section of strings followed by a lot of 00s.
That explains what he’s doing in this video. Thank you. I’ll have a look at it.
At first LAN, Wifi, Time and HDMI worked. Then I placed my personal .kodi Backup in /storage/ and it only shows the current time. Tried rebooting. Which file do I need to keep in .kodi if I replace this folder? Migrating from LibreELEC on Raspberry Pi 3. Got it: Forgot to reinstall OpenVFD…
How to check if AV works? Currently testing SPDIF. Can’t test if BT works, since I’ve no BT USB stick nor onboard BT.
Hi TheCoolest,
I realize this is an old thread, but I cannot get the vfd to work at all. I have a Sunvell T95Z Plus device, 32 gb rom / 3 gb ram. What do I need to do, tried several dtb files, even .vfd files I found in forums to no avail. I have wiped the original Android but have a copy of the original one, in case extracting a .dtb file is possible from the image. Please, would really love to use coreelec on this device, but fixing vfd and configuring the remote seem like the outstanding issues, maybe getting it to turn off the led anode as well when it is turned off, but that is no big deal after all. Let me know what to do in order to be of any assistance so that you can help me. Thanx
Hello everyone, I’m new here and I am asking for your understanding.
I have the same problem with the Sunvell T95Z Plus device, 32 GB ROM / 3 GB RAM. What I have to do, I tried several dtb files, and the vfd.conf file.
The display remains dark and the LEDs are constantly lit.
The blue led box is on, the blue and darker led box is off. The remote works
