Help x96mini is a brick
Hi evrybody,
I installed coreclec into the emmc memory and my tv box x96 mini s905w is now a brick.
I try to re install differents firmwares images with usb burning tool but the transfert stop (1% with the code [0x10103005]Romcode/Initialize DDR/Download buffer/Read item data failed).
I have no success with sdcard to re install the firmware.
I have connected a uart console and the system don’t want to boot on the sd card. Only on the emmc. I try to interrupt the boot sequence with the keyboard at startup (space, entrer) but nothing other that the emmc want to start.
This is the message i read :
GXL:BL1:9ac50e:bb16dc;FEAT:BDFC31BC:0;POC:3;RCY:0;EMMC:0;READ:0;CHK:A7;READ:0;0.0;0.0;CHK:0;
TE: 279411
BL2 Built : 20:32:17, Sep  8 2017.
gxl g6296b83 - xiaobo.gu@droid12
set vcck to 1120 mv
set vddee to 1000 mv
Board ID = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR3 chl: Rank0 16bit @ 792MHz
Rank0: 1024MB(auto)-2T-11
DataBus test pass!
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
aml log : R1024 check pass!
New fip structure!
Load bl30 from eMMC, src: 0x00010200, des: 0x01700000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x01700000, size: 0x0002c600
Load bl33 from eMMC, src: 0x00050200, des: 0x01700000, size: 0x00065e00
NOTICE:  BL3-1: v1.0(release):a625749
NOTICE:  BL3-1: Built : 11:25:15, Aug 25 2017
[BL31]: GXL CPU setup!
NOTICE:  BL31: BL33 decompress pass
mpu_config_enable:ok
[Image: gxl_v1.1.3243-377db0f 2017-09-07 11:28:58 qiufang.dai@droid07]
OPS=0x84
c5 6c 71 fc b3 de f0 78 2f 22 d4 f8 [0.749024 Inits done]
secure task start!
high task start!
low task start!
ERROR:   Error initializing runtime service opteed_fast
U-Boot 2015.01 (Apr 18 2018 - 10:08:22)
DRAM:  1 GiB
Relocation Offset is: 36eb3000
register usb cfg[0][1] = 0000000037f5a960
[CANVAS]canvas init
vpu: error: vpu: check dts: FDT_ERR_BADMAGIC, load default parameters
vpu: clk_level = 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpu: vpu_clk_gate_init_off
vpp: vpp_init
boot_device_flag : 1
Nand PHY Ver:1.01.001.0006 (c) 2013 Amlogic Inc.
init bus_cycle=6, bus_timing=7, system=5.0ns
reset failed
get_chip_type and ret:fffffffe
chip detect failed and ret:fffffffe
nandphy_init failed and ret=0xfffffff1
MMC:   aml_priv->desc_buf = 0x0000000033eb36b0
aml_priv->desc_buf = 0x0000000033eb59d0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
init_part() 278: PART_TYPE_DOS
[mmc_init] mmc init success
dtb magic 00000000
What can i do to unbrick my tv box ?
Can somebody help me ?
Bests regards.
You’re using the wrong firmware. Keep trying with different firmware till you find one that works.
Also please be aware that as per this article we do not provide official support for this situation:
Unsupported devices:
With the parameter x the ceemmc tool can be used for not by Team CoreELEC official supported devices.
Any support request for not official supported devices will be ignored.
This is because Team CoreELEC does not own every device on the market available and so we can not confirm the tool function with the unsupported device!
