Hi.
I have CoreELEC 19.2 running in a S905X3 device, connected to a 2019 Sony Android TV.
I have noticed in some 1080p videos encoded with HEVC in 10bit and HDR10, that the image “flashes” from time to time.
Here is the MediaInfo of one of those videos:
Video
Format : HEVC
Format profile : Main 10@L4@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 47 min 24 s
Bit rate : 5 578 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.112
Stream size : 1.85 GiB (87%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primar : Display P3
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 1050 cd/m2
Maximum Frame-Average Light Le : 274 cd/m2
My TV is configured with HDR set in “Auto” mode.
However, if I fix the TV HDR mode in “HDR10”, the video is played perfectly. Also, I play it directly in the TV itself with Emby Android app, there are no flashes at all.
That’s the reason I think that the HDR information is not well transmitted to the TV and, somehow, it doubts, disabling and re-enabling the HDR10 mode periodically, because it is HDR10 indeed.
Except these series of videos, I have been playing 2160p HEVC 10bit HDR10 movies without this kind of problems.
What do you think?
Thanks!
