I have the following problem.
I changed the resolution in coreelec 21 to a value that seems to be not supported by my tv/display. (In my case its 1080p120hz)
I already found a possible solution here but its not working in my case.
What i did:
Access box with SSH as root
Deleted the resolution.ini with the following commands:
mount -o remount,rw /flash
cd /flash
rm resolution.ini
reboot
After reboot the resolution.ini is created again unforunately with the same “wrong” value stated under kernel_hdmimode.
Second try was make flash rw, edit the resolution.ini with nano and changed kernel_hdmimode from 1080p120hz to 1080p60hz.
Also here same again, after reboot the value is set back to the problematic 120hz.
Hope someone has another idea how i can fix that issue without doing a total reset or a new installation from scratch.
Unfortunately not working.
If i check the file in a editor (nano) it still has the 120hz setting.
Also if i edit the parameter by myself and save the file it still is set to 120hz after opening the file again.
I don’t get why the changes are not being saved.
Permission says owner (root) has write permission and i’m logged in as root so this should work or do i miss something?
SSH:
systemctl stop kodi
cd /storage/.kodi/userdata edit the guisettings.xml with a editor, in my example nano:
nano guisettings.xml search for videoscreen.screenmode here you can change the resoltution to the “right/working” value. In my example:
0384002160060.00000pstd
What means 3840x2160 with 60hz
then save the file and reboot the box.
