I don’t believe Kodi on Android is capable of handling DTDL (image formats or mp4/mkv container). I thought that was CoreElec feature only.
Last thing to try. Keep cache size at 256MB, but instead of Adaptive caching, set to 8x instead. Does that make a difference?
If not, I might just upgrade box to Am6b+ and call it a day. We know it works on there. Maybe the reason it doesn’t work on S905X4 SOC is slower processor constraint, maybe it is a bug in Kodi with Adaptive caching mechanism, but whatever it is, easier to just change HW to solve it.
We know that S904 boxes struggle with VC-1 remuxes. This maybe another quirk between S904 and the faster S922 in Am6b+.
I don’t talk about “single track”. It’s about “dual track”.
The problem is on “single track” the BL+EL merge is already done, like start playback from beginning, so it does match 100%.
When “dual track” the EL and BL are merged how they arrive - and there is the issue. It sometimes does not seek correct and BL+EL result is a mixture of wrong packages.
You are correct. I repeated my test with the STDL MKV of Godzilla Minus One and I noticed that the 8-second buffer also sometimes dips down to 80% even before doing a seek. But it doesn’t affect playback, so that’s not really an issue.
It’s a historical Kodi buffer issue.
I tried to rework it a bit already but it must be reworked much more.
Now video buffer + audio buffer is linked together.
Both must reach a “good” level to work properly.
But like here after seek the video buffer get filled to 100% but the audio packages are so small so the buffer get only filled 1-2%.
But as now the video buffer is 100% there are no more packages read from stream at all. So the audio buffer can also never be filled → reset stream after a timeout. This happens until “enough” data is available again.
This handling is faulty and video and audio buffer must be separate handled to not block each other.
We “fixed” it my revert the buffer levels back to Nexus level again.
40MB for video and 32MB for audio.
But when this video seek a setup like 40MB video and 2MB audio is need.
Then it works again. But next seek does require 40/32MB again…
Such rework will be a long term work as it affect playback for all media on all devices.
I did something about it in past and will need to check how this works now. I am not sure if this would be upstreamed as they have no need for it because if no media support at all.
I know. Some release groups did this some years ago when they just started with DV remuxes. I did some testing with them earlier this year when Portisch was working on FEL support and found out that if you feed such a DTDL MKV to MakeMKV, it will “fix” it for you by converting it to STDL.
I’m trying to install CoreElec on my Dune Homatics box but keep getting thrown into the Android Recovery screen. What do I do from there? I tried the reset button method and the boot CoreElec app with the same results.
