Homatics Box R 4K Plus
Yes, it’s exactly how it’s supposed to work.
Thank you for the suggestion, I have reboot.APK to install , but the box does not restart. Can you guide me on how to restart the box?
EDIT:
Thank you very much, I found the RESTART option and your method works very well. Thanks again.
My box is new HOMATICS and does not have an AV port. the old HOMATICS have AV port.
Interesting! Do you have a picture of the box or link to that version?
new HOMATICS
Hello, I have just installed CE 21 on my dune HD homatics, for DV videos everything is fine, however when I launch a video in HDR, HDR10… I have artifacts and the colors do not match!
I have a panasonic 65hz1500e tv.
If anyone can help a newbie!
Thank you. Now I’m still a bit curious for what’s inside (motherboard revision), but I ask my contact for that.
Please start a DV video in RGB and then run dmesg | paste. Before ensure all is set to auto!
My LG C1 is playing back DV 12bit RGB.
Minimal EL looks good
My Pana JZ1000 is playing HDR10 in 12 bit YUV444. No color artifacts
Which medium for CE is recommended for Homatics? Usb disk is quite slow, sd card slot is missing. Thx.
usb stick and this hack that puts storage on emmc
Blank screen with Gemini man
http://ix.io/4tlL
Set the GUI to 1080p and try again. I think a frame switch will be required right now.
That works Thanks
I am super excited about finally have DV Native Support in CoreELEC!
I have 2 questions:
1: If installed to emmc, is there a way back to factory? (Dune-HD Version)
2: What is the difference between the 8.1 and 8.1-mp
emmc install not supported since partitions are needed from android.
so we will ALWAYS need to run coreelec from usb?
http://ix.io/4tm2
Ok, I think it’s switched afterwards to RGB so the auto detection for the colour depth is not correct anymore and the 420 is used. And there 12bit is possible.
Tv Sony, Homatics, CE 21 ne nightly. Dv is working only if 12 bit 422yuv is manualy set. Dv conversion is ignored, only DV-LL is working.
Tested on Dv profiles 5.6, 8.6 and 7.6
