I booted from Android to CE with Ethernet working, and I want CE to add G5009CG driver to make my Ethernet Normal working.
Please try on CE ssh:
mf
cd /flash
fdtput -t i dtb.img /soc/ethernet@fdc00000 internal_phy 2
sync
reboot
We also have the same PHY mounted so we don’t know what is different as no source is available.
The YXZ TRANSFORMER G5009CG is a transformer and need no driver ![]()
I executed the command above, still have a WIFI connection, no Ethernet connection. Thank you.
Can it help?
CoreELEC2:~ # fw_printenv | paste
http://ix.io/4tt1
aml_dt=sc2_s905x4_ah212-id5
Follow the wiki instructions to export the DTB.
SSH into CoreELEC and type:
dd if=/dev/dtb | gzip > /storage/backup/dtb.img.gz
dtb.img.gz (99.1 KB)
All is OK! Thank you!
Does DV is played in current version of Coreelec as player or display led please? I would like the TV is taking care about the metadata
Preferred is display LED, RGB as it gives best user experience. With today nightly there is a user option to enforce player LED if the TV support it.
Just an idea, could it be that some kind of pull-up/pull-down resistor has been ommited in some board revisions thus controlling some enable signal depends on soc and firmware to put some gpio pin into some state neede to enable ethernet ic?
If so, you can’t see it on the revisionnumber of the motherboard or that of the Ethernet chip. I have 2 exactly same boxes, really no differences visible, and only one has the cold boot problem.
hey guys , I have a ugoos am6b plus, use Kodi(21, nerds) can playback DV(FEL), but ce only have ng, no DV, can u make it possible?
Unfortunately, I can’t use a LAN connection either. Although eth0 incl. MAC address seems to be found by the system, this connection is not visible in Kodi.
CoreELEC-R4:~ # ifconfig
eth0 Link encap:Ethernet HWaddr D4:CF:F9:A9:A0:A6
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:42
It doesn’t get an IP address from the DHCP server either.
A USB Ethernet adapter (2.5GBe, RTL chipset, 0bda:8156) seems to work, but requires the second USB port, which I need for a 2.4 GHz keyboard dongle.
usb0 Link encap:Ethernet HWaddr 00:E0:4C:68:01:80
inet addr:192.168.XXX.XXX Bcast:192.168.XXX.XXX Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:57913 errors:0 dropped:1276 overruns:0 frame:0
TX packets:15176 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:77391072 (73.8 MiB) TX bytes:1206214 (1.1 MiB)
Can someone with not working ethernet try “regular” CE 20.1 image (on extra USB stick)?
That’s what I’am using. Doesn’t work on both, CE20 and CE21.
I tested many CE builds, also this one. Only because another user I had contact with did not had any problem with his Ethernet connection and the R Plus. It was only after I received several other R Plus boxes that I realized, it was the box itself that was the cause of it. But I keep trying (it’s easy done).
When there is need for a (distance) test R Plus box with the issue, you know how to reach me ![]()
Thanks, this is much better.
CE-NE21 0414&0415, as long as the color depth is set to auto and the color sampling is set to auto, then the LLDV output is greenish and must be manually set to 422/12 BIT color to be normal.
My TV is Sony and does not support display LED.
Play 2160P AV1 HDR10, cannot output HDR, output SDR.
We will try to include a driver want maybe solve this issue.
