Thank you frodo I have just ordered a flirc and will pick it up tomorrow. I will be happy to get this sorted. The Kodi side of coreelec is great but the homatic side is a bit of an arm wrestle. I just hope the IR operation is as good as the bluetooth. I have been very impressed with how snappy that is.
Shout out to all the problem solvers on this forum…you guys rock!!
First unpair the homatics remote from the android tv os , then program the flirc in the pc, use kodi remote, then pair in the android again. IR will in CoreElec use, BT will in ATV use.
What is the setup regards Booting mnd with the Homatics plus? I am guessing a USB drive with the Image written as I can see no SD Card slot. The reason I am asking is I ordered the Homatics Box R 4K Plus earlier today, realise it may not be here for at the most a couple of weeks, just trying to get all of my ducks in a row so to speak.
CEC works great for me.
Both the Dune and Homatics are basically the same. Nokia and RockTek are also basically the same, same platform, different plastic case.
There are some differences in board revisions which are out of your control, but overall it seems that most of them work fine. The edge cases are being addressed.
Flirc upgrade certainly fixed some issues but one problem persists and that is shutdown. If I use the shutdown button all I get is the Kodi power dropdown and choosing shutdown works but there is no way to restart other than by cycling power to the homatics box. If I choose to restart from nand ,and then operate power button, box shuts down and will restart but only in ATV. Still need to cycle power to boot to Kodi. Any tips?
Im use reboot to android, and there, sleep/power off.
No any chance. Full shutdown not supported in Android.
Or you can stay on Coreelec, without shutdown…
