Do the CE 21 nightlies support playing HDR10+ files (note the “+”)?
I have tried playing some files that I know are HDR10+ because they play as such when I use the Kodi 21 nightly that is installed directly on my Philips OLED with Android TV 11. But when I play them in CE they play as regular HDR.
For me it stays “HDR10Plus Supported: 0”. I have the Dune model. Can it have something to do with the firmware version? Dune is behind compared to Homatics and I noticed that on Android HDR10+ also doesn’t work. I think I read in the Telegram group that an issue regarding HDR10+ not working was fixed in the latest Homatics beta?
No, it’s your TV not supporting HDR10+ as it’s reported not supporting it by delivered EDID. When you have a AVR between try direct connection to TV as they are known to cause troubles.
The player can not do anything when the TV does not support it or if he “tells” the player the wrong information.
you can try to use an option for restart in the ATV Settings. I’m at work so unable to describe the exact menuitems/path ATM… (try Settings → About → Restart)
Sorry if this has been answered. Is it possible to force all video output as DV? With Fire TV Cube 3, which has “Always HDR” (really always DV if it detects a DV display or a HDFury), and Zidoo Z9X, which has Dolby VS10 engine for all, one can force LLDV tonemapping to all videos… which generally results in better PQ. Thanks.
I highly doubt any tonemapping results in better pq, but that’s just my opinion I guess.
And to answer the question, no. DV will activate when DV content is played.
Thanks. Several of us on AVSForum have tried ‘forced’ DV on everything with Zidoo/Fire Cube3 and results have been noticeably better than vanilla SDR, HDR or even HDR10+. This is with a HDFury in the chain and using AWOL LTV-3500/2500 projector.
So you’re forcing tone mapping to alter the intended colour space of the content to an artificial representation and you think that’s better? How do you generate the scene specific dynamic data when it doesn’t exist? Don’t know why you’d waste money on a HDFury and then set your devices to do that. Seems counter-intuitive.
