Homatics Box R 4K Plus
I restarted tmate
ok, updating soon.
when the update is finished please enter CE settings - hardware and change Motorcomm option to assembled. After a reboot eth should be working.
Confirmed setting works, Thanks
ceemmc -x error
Free space of ‘partition CE_FLASH’: 512MB
Warning: Could not find ‘dto’ partition!
Could not find ‘CE_STORAGE’ partition!
Failed to read size of partition ‘CE_STORAGE’!
Failed to create new partition table!
You trying to install coreelec to emmc?
Thats not possible
I thought the script was updated to include s905x4.
Choppy avc1 video that plays correctly on the vim4
kodi
http://ix.io/4lMu
dmesg
http://ix.io/4lMv
dispinfo
http://ix.io/4lMw
Its not about the script. Its Google certificed box, not able to manipulate the android partition. It’s also a wonder that CE run from pendrive.
I made fresh install, latest CE ng nexus nightly, with generic dtb. All working. Bluetooth, wifi, gig lan. Just the Original remote control no.
@rome1931 Whats your fw number in your homatics box? Use stable or beta firmware from homatics?
I’m on the stable
Can you upload your working coreelec dtb.img , because one of my friend need too. Thanks
Its the generic sc2_4g_1gbit.
But you have updated version from the devs, when I read good.
No it’s the same, he just added a new setting to have Ethernet working.
And when you made new installation, that settings will be gone?
No you have enable the setting for Ethernet to work after reboot.
@Portisch I have friend, who hat same issue as rome1931. He has no ethernet. Which dtb, or which CE image can he use ? He doesn’t see a similar setup in CE>Hardware section, what you mentioned. Thank you
Use last Amlogic-ne nightly
https://relkai.coreelec.org/?dir=Amlogic-ne/ce-20
Thanks, but the friend not a coreelec member. He nstalled the ne nightly but no Ethernet. Some post earlier rome1931 installed ng nightly succesfully here with your help.
