enter CE settings - hardware and change Motorcomm option to assembled . After a reboot eth should be working
Only works on ne
Only works on ne
I was able to get a img file from manufacturer
Android tv fw image?
Can you share the file?
Thank you
@Portisch Can you see whats insideā¦
Android 12 wonāt be 64 bit on this box.
But maybe Portisch can any usable thing find for the coreelec, like remote config, or anything.
This still works as the next best thing to ceemmc.
noticeable speed improvement in gui and thumbnail loading. coupled with the Bluetooth remote very snappy.
Have you able to working the bluetooth remote from homatics?
Yes I do have it working, all buttons.
70-local-keyboard.hwdb
udevadm hwdb --update
udevadm trigger -s input
reboot
adjust as needed with keymap editor
b21.txt
Moderator update:
To pair the remote control - On the remote, press and hold the āHomeā and āBackā keys together for about 4 seconds until you see the remoteās LED blinking.
Thank you!
I might have found the correct dtb
running fw_printenv I get
aml_dt=sc2_s905x4_ah212-id6
fdtget -s dtb.img
3/4: Found dtb in multi-dtb āamlogic-dt-idā: sc2_s905x4_ah212-id6
Have you saved the dtb, and placed to coreelec usb, and working?
I think it needs to be compiled with kernel.
Thanks, and there are the source (.dts) files: [link]
Portisch, what is the superpartition?
When I installed the new CE omega nightly, and try to load in the homatics box, there is a popup to missing superpartition, and not able to play media files. I set all bluetooth, wifi Ethernet, but cannot play any files.
thanks
https://source.android.com/docs/core/ota/dynamic_partitions/implement
The devices from Homatics are on the way so we will be able to check it soon by ourselvesā¦
Good news ![]()
