I requested mine to have the firmware update made available and they did.
Just email support@homatics.com with your serial number and ask for the firmware update to be made available.
It is still not clear to me when issue occur. If after suspend/resume then don’t expect much help because this feature is just not supported.
even reboot from menu is similar result.
Try a different USB memory stick vendor and type.
Hey all!
I have got a little problem with my nokia 8010 with CE installed. Everytime I plug in my power to start my tv, my onkyo receiver and my nokia box, the nokia box only shows a coloured screen. Seems like a HDMI handshake issue. I have to pull the nokias powerplug and restart it again to get the handshake correctly done. Is this a known problem and is there a solution?
You must first power on the tv, than the receiver and the box.
yep i have that too.
Basically a one button for your home cinema is currently not possible ![]()
but the devs are pretty active here <3
i just added a remote power plug to the homatics box. (and yeah indeed its again a 2nd remote in the living room xD my wife is not amused about it)
ok will try and report
btw do i need to format specific format like ntfs, exfat ? current one is ntfs
Thanks for kind support and patience, i did try a new usb stick and it seems i m getting a new issue/side effect. Now i m pretty much on default settings and when i turn off my whole system using sony tv remote, it does turn off everything(tv, soundbar, and dune box) and light goes to red from green, but after sometime it wakes the whole system up and turn to green light again
Is this due to some timer settings or some background activity waking things up
Is there a key combination I need to use after Firmware update from Homatics it seems not to be booting from the Corelec Image on USB Stick?
Just found this and it rings a bell
‘Also called the “toothpick method”.
Disconnect the power supply, insert boot media, push and hold the reset button while connecting the power.
Wait until the CoreELEC logo appears, then release the reset button.’
Will try this later
Once this method, every time there is a Android TV OS update for the box.
Yup just done the pin method, All working
adb shell reboot update is easiest. Of course, USB debugging must be enabled first.
Also is there a way to use my premium b25 remote in ir mode. Is there a remote.conf file which i can use as bluetooth mostly dont work in coreelec easily, even after trials and pairing multiple times
Hi do you have a working remote.conf for B25 or B21 remote
Read back or use the search option.
remote.conf
I searched through this topic and couldn’t find anything: was anyone able to get Harmony Hub working with this box?
