Thanks. Does this work for the Homatics box, though? I saw some claims that it doesn’t even have IR
Hello everyone
First of all many thanks for patience and responding to questions. In summary my system is now working fine and seems with new usb stick it is booting back to coreelec and not android
Secondly used ir remote config file from frodo19 and that is also working super fine
For the first time watched some demos and sample movies and pretty happy with system
Now I need to buy some blue ray rips and build a library
Thanks once again and keep up the good work
Anyone using Homatics tuner with this device? If yes with which Android firmware version?
No ir on Homatics box. People in here added one to their box.
Thanks again. Through a USB dongle? Any particular one that’s recommended?
Flirc usb useable . Or assemble this type of IR receiver diode to the motherboard.
Thanks. Any instructions for assembling the diode?
Sorry, no. You lose the warranty, and can brick your box.
You need to check your CEC settings in Kodi. https://kodi.wiki/view/Settings/System/Input (I think CEC devices will appear as peripherals?)
By default Kodi switches all CEC-connected devices (TV and AVR) off when you shut Kodi down.
I use it (sometimes), now with the latest V5310 build. I got the DVB-T/T2/C version of Homatics.
Just installed the 5130 version of android on a dune box and updated to CE version 07-21, I think. There were two things that I liked - dolby vision notification popped up on my tv when playing dolby vision content, the second - I was glad to see the latest changelog pop up in CE, when booting for the first time after the update.
Thank you, CE team!
Edit: hm, but browsing my NAS smb share is terribly slow now, it takes more than 10 seconds to load the contents of folders, anyone else? 4k movie played fine, so it’s not an issue of lan speed
Mine seems to take a long time to boot and become responsive. On my N2 for instance the EPG import from tvheadend takes mere seconds but on the homatics it seems to take a lot longer and sometimes the box becomes unresponsive while this happens.
I’ve attached the kodi.log it generates while booting but obvious standing out that would cause that sort of issue.
kodi.log (50.1 KB)
Nokia 8010 here, neither codes given by Vex:
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/1077
Nor given by frodo19:
https://discourse.coreelec.org/t/homatics-box-r-4k-plus/19596/985
Worked for me.
So, this is my rc_keymap for NOKIA 8010 if it helps somebody:
# table NOKIA, type: NEC RC6
0x801c0001 KEY_POWER
0x801c8001 KEY_POWER
0x1d0213 KEY_1
0x1d0212 KEY_2
0x1d0210 KEY_3
0x1d0217 KEY_4
0x1d0216 KEY_5
0x1d0214 KEY_6
0x1d021b KEY_7
0x1d021a KEY_8
0x1d0218 KEY_9
0x1d021e KEY_0
0x1d021f KEY_PREVIOUS
0x1d0202 KEY_NEXT
0x1d0250 KEY_REWIND
0x1d0203 KEY_PLAYPAUSE
0x1d024c KEY_FASTFORWARD
0x1d0201 KEY_STOP
0x801c0004 KEY_VOLUMEDOWN
0x801c8004 KEY_VOLUMEDOWN
0x801c0005 KEY_VOLUMEUP
0x801c8005 KEY_VOLUMEUP
0x801c0009 KEY_MUTE
0x801c8009 KEY_MUTE
0x1d0204 KEY_CHANNELUP
0x1d0206 KEY_CHANNELDOWN
0x1d025c KEY_HOME
0x1d0259 KEY_UP
0x1d0251 KEY_DOWN
0x1d0254 KEY_LEFT
0x1d0215 KEY_RIGHT
0x1d0255 KEY_ENTER
0x1d0219 KEY_BACK
0x1d0209 KEY_MENU
0x1d0211 KEY_CONTEXT_MENU
0x1d0208 KEY_INFO
0x1d021c KEY_EPG
0x1d022e KEY_FAVORITES
0x1d020a KEY_RED
0x1d024d KEY_GREEN
0x1d020e KEY_YELLOW
0x1d020c KEY_BLUE
By the way, I am unable to poweron the device with the remote after shutdown, if someone have an idea, you are welcome.
Thanks a lot to the devs and the community for the good work, waiting for Nokia updating the firmware to v11.8.5310, because my device doesn’t offer upgrade anything bigger than v11.8.4674 for the moment.
Have a nice summer you all!
Hello Friend I have a Nokia 8010 can you please explain how and where to put that on CoreELEC, usually I use FileZilla to send files to the box. Thanks in advance Friend and have a awesome Summer too.
I hope you don’t mean me, my “Homatics 4K plus” and “Ugoos AM6B Plus” have proper DV license.
What I’m looking forward is “KODI 20” because of my plugins compatibility.
Hope it’s more clear now…
Yes now it’s clear. The amount of devices with DV support is so limited that you can refer to them by their model name.
That Ugoos model is no certified Android TV box, or is it?
If by certified you mean Widevine L1 for streaming services then it’s not.
Android firmware is just normal Android(not ATV) with several special features.
If you mean DV license (S922XJ CPU) then yes.
Any chance of fixing the Homatics sleep/wake bug?
