Yeah ,it appears just fine and can be paired and removed just fine with bluetoothctl ,but still no input device is created .
Just tested and surprisingly ,this B25 it works with my LG G2 tv,only OK ,BACK and another few buttons aren’t working (just as it happens with B19 and B21 on CE).
I concur, I just got my Rocktek G2 and the remote is just totally SOL, it shows up as “Paired” but no luck after that. The latest nightly from 2 days ago totally broke it and Bluetooth was initially saying it was disabled. Now Bluetooth works, but the remote even if it is paired doesn’t control at all. Please let me know if any debug is needed.
@vpeter after the latest CE21 nightly ,the Homatics B25 started to work .
Of course ,it still needs the correct hwdb,because several buttons aren’t working .
There were issues with Omega in general that were being solved upstream by TK so as it’s still in Alpha stage the team decided to backport DV to CE20.
You can use CE21 knowing that some probl Ms may emerge.
Hey @pretoriano80 what was your issue, and how did you get it sorted out? Can you point me to some debugging tips please(This is the issue of the Rocktek G2 Bluetooth Remote not working)
It is paired & connected, but I am not able to navigate around with it. Can you please point me to a thread which gives me some debug information about the evtest please?
For my G2, since I go back and fourth with Android, to avoid pairing issues I just use BT for Android, because I can use all the special keys, and I use an USB HID RF remote for CE.
