Homatics Premier 4K Pro
Btw…
If I boot CE the SSD/HDD in bay is not detected. When I pull out/push in the drive is detected and working fine. I can also use the suspend mode to detect the drive in bay after wake-up.
Exist a command line to “scan” the usb ports again after coreELEC is booting? Maybe I can put it to autostart.sh or something like that…
Maybe it could work with poking /sys. Something like
https://billauer.co.il/blog/2013/02/usb-reset-ehci-uhci-linux/
Here are some pictures of a little bit of disassemble…
Maybe someone is interested in what’s inside…
Thanks for this FoLeY, very interesting !
It looks like they added a daughter board acting as a USB3 hub with the HDD bay. It makes even more strange that the HDD won’t boot as it is obviously on the same interface as the external USB3 ports :roll_eyes:
