Hi, I don’t know if this question is in the right forum, I have a tvbox with the skin aeon nox silvo and in the photo menu, I have the widget with access to a folder with images, which I have renamed in alphabetical order, but in the widget they come out completely unordered, even though they are named from 1 to 30, is there any way for this not to happen and order them correctly? Thanks
I would have thought logically, the best place would be the Kodi forum under Aeon nox silvo
