I can’t find them under Services. Are they not supported? Is it possible to download them manually somewhere? It’s for XBox DVB-C tuner and TVHeadend
They are already included, you just need to enable them.
Where do I do that if I can’t see them under Addon → Services?
Go to Addons, CoreELEC repository, Services and it’s there.
That’s where I am looking and no DVB drivers of any sort there. TVHeadend server is there but no DVB drivers.
no, on EOL system it’s under program addons, device driver select
Thanks, found it. The TBS drivers works with an Xbox live tuner.
