Hi! How do you play cd’s on Kodi? I have a Beelink device running Coreelec. When I plug in a portable cd/dvd drive nothing happens. In settings I found dvd and cd autoplay, but still nothing. What am I missing?
Probably the USB port can’t give it enough power to work. You may have to use a powered hub unless your DVD player has a power input.
With mine I had to use a powered USB hub.
Ah, ok. Thanks.
That would make sense!
The cd/dvd player is not powered.
My device is a Beelink GS-King X
Processing: IMG_20230910_192950_699.jpg…
