Hey! I’m a Ugoos AM8 Pro owner with UR01 and UR02 remote controllers. As my Ugoos is tucked away on a shelf, it’s quite inconvenient to have to open it every time I need to boot CoreELEC. Is there a way to boot it using Bluetooth? From what I understand, I need a Bluetooth dongle for that.
To add to that, some BT remotes issue IR from the power button, some even issue IR+BT from the power button at the same time. Check whether you can see the IR LED light up through your phone camera. Or cover the front of the remote while trying to power on with the remote.
