I have no need for ipset and iptable embedded in CE kernel, so no config to share.
After modifying the configuration file and compiling again, the following error occurs:
armv8a-libreelec-linux-gnueabihf-g++-10.3.0: fatal error: Killed signal terminated program lto1
compilation terminated.
lto-wrapper: fatal error: /home/sun/CoreELEC/build.CoreELEC-Amlogic-ng.arm-19/toolchain/bin/armv8a-libreelec-linux-gnueabihf-g++-10.3.0 returned 1 exit status
/home/sun/CoreELEC/build.CoreELEC-Amlogic-ng.arm-19/toolchain/lib/gcc/armv8a-libreelec-linux-gnueabihf/10.3.0/../../../../armv8a-libreelec-linux-gnueabihf/bin/ld.gold: fatal error: lto-wrapper failed
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
FAILURE: scripts/build kodi:target during make_target (default)
*********** FAILED COMMAND ***********
ninja ${NINJA_OPTS} ${PKG_MAKE_OPTS_TARGET}
${SCRIPTS}/build "${1}" "${PARENT_PKG}"
FAILURE: scripts/install kodi:target has failed!
The following log for this failure is available:
/home/sun/CoreELEC/build.CoreELEC-Amlogic-ng.arm-19/.threads/logs/310.log
>>>kodi:target seq 310 >>>
[339/344] [FAIL] install kodi:target
Parallel build failure - see log for details. Time of failure: Fri Jan 20 08:50:35 CST 2023
make: *** [Makefile:9: release] Error 1
sun@sun-Virtual-Machine:~/CoreELEC$
How to solve it? thanks
Has been resolved, the original is because of insufficient memory.
Thanks for everyone’s help, I have successfully compiled, and now my device has full proxy capabilities, very happy, thank you.
I made it, do you need a configuration file or compiled firmware?
You want to share your info? Or make a PR so we can include it in CE?
I need a compiled firmware please.
I’d love to contribute a little bit to CE, but I don’t understand what a PR is? I don’t know how to program, and it took me 20 days to figure it out one after another. What should I do?
Tell me your email, my processor is s905l3a, you may need to pack it yourself.
Check your email, i already send you a message ![]()
has been sent to you
Can you please share your .config file? Thanks.
Ok,Tell me your email
I’ve sent a mail to your email, please check.
Best regards.
@gnsx Can you send me your config file please? Thank you very much! I have sent a email to you. Thanks!
can you give me your config and a compiled firmware please thanks
Did you try Amlogic-ng as the build system suggests? I suspect the wiki needs an update
Why dollar sign $ after CoreELEC?
