I have download the project of CoreELEC from git hub. I want to know the compile command of S905D3.
PROJECT=Amlogic ARCH=arm make image
This command without DEVICE is right? If I enter the DEVICE=S905 . It will prompt invalid DEVICE when starting to compile.
PROJECT=Amlogic-ng ARCH=arm make image
Thank you I will try again.
Hi Portisch. I have compiled the project. Is the image in CoreELEC/target/ ? I find there is four CoreELEC-Amlogic-ng-arm-9.2*******.tar. Which one should be used from the VIM3L?
You only have one tar. This is used for update.
Use the …generic.img.gz for VIM3L when you create a new CE boot media.
Ray
19 July 2020 08:42
#6
The only reason you have 4 tars is because you build 4 times.
Thank you . I have test the img . It works well.
And I have another question. If I want to modify dts file. What should I do to make the modified file recompile?
