I can not find the option to disable the backround playback for example when i return it plays in backround.
Anyone has an solution?
Yes, press Stop button
There is usually an option in the skin settings, it’s a skin dependent setting. I don’t think the option exists in Estuary, you’d have to try a different skin.
For a solution that works with any skin add a fullscreenvideo section to your keymap with the back button mapped to stop.
If you don’t know the id for the back button on your remote then use the Keymap Editor add-on, just make sure you only add it to Fullscreen Video->Playback. NOT GLOBAL!!!
<keymap>
<fullscreenvideo>
<keyboard>
<key id="your_back_button_id">stop</key>
</keyboard>
</fullscreenvideo>
</keymap>
This worked like a charm , nice ! thank you so much
