I would like to ask you for your help. How can I disable onboard bluetooth and use usb bt dongle instead? I´m running on Khadas Vim2 Max, CoreELEC 9.2.
The problem is, that onboard bluetooth has very limited range, so I would like to use USB dongle.
Thank you very much
M.
Do you need to disable it?
Try plugging in the dongle, just choose the external one
Where to choose it, please?
Coreelec under blue tooth devices, when you turn on the device, you will see them.
I can choose devices, but not usb dongle…
From what I understand,you need to blacklist the device that you don’t want to use.
I don’t know if This may be of help but searching for blacklist might yield more helpful results.
I´m trying to do that, but don´t know, what to put on blacklist…
CoreELEC:~ # lsmod
Module Size Used by
bnep 15079 2
hci_uart 34102 1
btsdio 4874 0
bluetooth 372939 24 bnep,btsdio,hci_uart
6lowpan_iphc 10231 1 bluetooth
8021q 21855 0
avl6862 268013 0
dhd 902626 0
mali_kbase 420977 3
ir_rc5_decoder 2735 0
ir_sanyo_decoder 3115 0
ir_jvc_decoder 2799 0
ir_lirc_codec 5340 0
ir_nec_decoder 3615 0
ir_mce_kbd_decoder 5212 0
ir_rc6_decoder 3823 0
ir_sony_decoder 2649 0
lirc_dev 11896 1 ir_lirc_codec
cfg80211 417431 1 dhd
meson_ir 4389 0
rc_core 19532 11 lirc_dev,meson_ir,ir_lirc_codec,ir_rc5_decoder,ir_nec_decoder,ir_sony_decoder,ir_mce_kbd_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_sanyo_decoder
aml_fe 7513 0
khadas_fan 5673 0
aml 87685 1 aml_fe
dvb_core 105934 2 aml,aml_fe
wireguard 127392 0
wifi_dummy 894 0
amlvideodri 13210 0
videobuf_res 5690 1 amlvideodri
videobuf_core 18248 2 amlvideodri,videobuf_res
videodev 144588 1 amlvideodri
dwc_otg 261556 0
fbcon 40863 0
bitblit 4820 1 fbcon
softcursor 1344 1 bitblit
font 7399 1 fbcon
btsdio should be the onboard bluetooth.
Unfortunatelly it´s not. When I go to BT settings in Coreelec, it again finds some devices…
According to this thread the location of the blacklist.conf is different,
I’m not sure exactly which option to blacklist as there is bluetooth, btsdio, bnep and hci_uart but you could blacklist each one in turn and then plug in your dongle to discover which combination works.
Many thanks to all of you. It works with hci_uart…
