I have an N2 with the SPDIF Option installed and want to feed PCM via Optical Cable to my Headphones.
Will be switching between 2 Audio Profiles, Headphones vs Sound System, using the Add-on Audio Profiles. So want to set one profile that is just PCM, as that is all the Headphones will except.
The add-on is not important. I just need to setup the audio for PCM Only via SPDIF. Then I save it to an Audio Profile and recall it when I want to use the Headphones.
Just need advise on how to setup CE/Kodi so I have PCM Only via SPDIF no matter what the N2 is playing.
