Hi, I’ve been using OSMC on a Raspberry Pi for a few years and now I wanted to be able to play H.265 and 4K video so I switched the Le Potato. I installed the latest CoreELEC and everything works perfectly but I can’t control KODI from my remote anymore. The remote is a Sony bluetooth touchpad (came with the TV) and it worked perfectly in OSMC. I know that there is a jumper on the board to enable/disable CEC and I’ve tried both settings but without any luck.
Also when I ask the TV to show my connected devices it does not list KODI only my PS4 and IPTV box. If I select HDMI port 2 (where KODI is connected) I get the picture but I must then use a keyboard to control it.
Is there anything else I should do to get it to work, (I’ve tried different HDMI 1.4 and 2.0 cables)? The Sony 4K TV is 3-4 years old.
Best regards
Nicke
