lmza
21 October 2019 12:50
#1
Hi
I want to pass a parameter value to the kernel module in order to solve a particular problem I have. To be more specific, I want to pass:
force_sec_sf=1
force_pes_sf=1
to aml_fe.ko (which is part of the crazycat tbs drivers add-on).
How could I permanently add these parameters when the module loads?
Thank you.
vpeter
21 October 2019 12:56
#2
Try adding this
aml_fe.force_sec_sf=1 aml_fe.force_pes_sf=1
to file /flash/config.ini in parameter coreelec (must be uncomment). Like
coreelec='aml_fe.force_sec_sf=1 aml_fe.force_pes_sf=1'
lmza
22 October 2019 04:17
#3
Hi vpeter
Thanks for the feedback. I am using amlogic box (Mecool k3 pro). There is no default config.ini.
The compiled aml_autoscript has the
setenv bootargs ${bootargs}
option which is probably where the parameter needs to be defined?
I tried to create a new config.ini as suggested, but the parameters were not processed.
I have also tried:
bootargs=‘aml_fe.force_sec_sf=1 aml_fe.force_pes_sf=1’
in the config.ini, without success.
Not sure how to pass the “bootargs” to an already compiled aml_autoscript.
If you make any changes to aml_autoscript then these need to be compiled and then for aml_autoscript to be parsed you have to press the reset button on your device when booting like in the initial setup.
