bazzle
13 September 2023 12:00
1
Subtitles are very bright when HDR video is played. Returns to normal when SDR etc.
Bit of a bugger having to change it every time I use HDR.
Currently using 20.2
I found this in the Kodi wiki “GUI peak luminance in HDR PQ mode”
https://kodi.wiki/view/Settings/System/Display#GUI_peak_luminance_in_HDR_PQ_mode .
I believe this is what I am seeking but I cannot see a way to set in CE. Is this still a thing?
Thanks in advance Baz
set your subtitle color to grey.
thats what i did
bazzle
14 September 2023 08:27
3
Thanks…that works a bit, but it would be nice if it had the menu command linked above.
Not really the answer but a poor workaround.
I think, this special settings used just in Windows kodi, and not exist in other OS.
freddy
15 September 2023 16:46
6
Thought maybe could change Opacity in Subtitles settings.
Would reduce brightness
bazzle
21 September 2023 09:06
7
it does but need to change back in sdr.
I use same grey color both hdr/dv and sdr sources, it works perfect.
freddy
21 September 2023 16:18
9
Yes of course is pain in the #@$
Like Audio Profile addon where you can save multiply Audio configs.
And switch between/ select for playback.
Try this method
Install Audio Profile addon for Kodi
Create Audio Profile 1 with Opacity set to what you need to reduce brightness/ Subtitles
Save as Digital HDR for example
Now reset Subtitles to default and create second Profile
Save as Digital Default for example.
Now can switch between during playback
Make sure you go to Extras in Audio Profile settings and enable all functions.
Should work
Happy Testing
Nice touch for those, to whom need, if that works.
freddy
21 September 2023 21:11
11
Doesn’t work though.
I couldn’t get it to
I just tested on couple of boxes
Of course only changes in Audio settings are saved in Profile.
Iam the Fool
Not fir first time.
Someone needs to build/dev
Video Profile addon for Kodi/CoreELEC
All versions
Okay iam editing to Redeem Myself
I knew it had something to do with Profiles.
You create a USER Profile
With Opacity set to your liking for Subtitles
Nothing to do with Audio Profile Addon
Much the same as different User logging in to
X-Box.
This method actually works
Tested multiple times now.
Can switch between User Profiles easily
Also can map function to keyboard etc…
Happy Testing
system
Closed
22 December 2023 03:12
12
