Hello, I’m using Mecool remote with Beelink gt king box (“remote.cfg” file) and everything’s working great except key repeating when I long press, let’s say, arrow keys.
With the same “remote.cfg” file on Mecool repeating is working fine.
How to set it, if someone knows (step-by-step, please)?
There is no ‘step by step’.
Just play around with these values in remote.conf till it works to your likings (the values bellow usually do the trick):
repeat_enable = 1
repeat_delay = 130
repeat_peroid = 120
release_delay = 20
Remember to reboot between tries.
Thanks, but I already have:
factory_code = 0xff000001
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 0
in my “remote.conf”.
The problem is not in repeating frequency, but in the fact that repeating is not working AT ALL on my gt king with 19.2 rc3.
stm
4 October 2021 20:00
4
Same problem here with N2+ and 19.2rc3. With remote.cfg and a Mecool remote repeat does not work. On the other hand I never had a problem with meson-ir until I started to use the Estuary Mod v2 skin…
Pachis
30 October 2021 22:06
5
Same problem here with a Mecool K1 Pro and the following remote.conf.
#amlogic NEC remote MeeloUNO KI-Plus KII-Pro KI-Pro
work_mode = 0
repeat_enable = 1
repeat_delay = 40
repeat_peroid = 39
release_delay = 121
debug_enable = 0
key_begin
#video strong
0x59 31 #power
0x19 113 #mute
0x0e 130 #info
0x0d 172 #home
0x51 14 #del
0x12 44 #mouse
0x4d 18 #epg
0x11 23 #dtv (info)
0x45 46 #menu
0x05 1 #exit
0x06 103 #up
0x5a 105 #left
0x1a 28
0x1b 106 #right
0x16 108 #down
0x55 104 #page+
0x15 109 #page-
0x52 2 #1
0x50 3 #2
0x10 4 #3
0x13 115 #vol+
0x56 5 #4
0x54 6 #5
0x14 7 #6
0x17 114 #vol-
0x4e 8 #7
0x4c 9 #8
0x0c 10 #9
0x0f 11 #0
0x4a 19 #fr
0x48 33 #ff
0x08 51 #prev
0x0b 52 #next
0x46 57 #play/pause
0x44 45 #stop
0x04 64 #pvr
0x07 132 #repeat
0x42 59 #red
0x40 60 #green
0x00 61 #yellow
0x03 62 #blue
0x1f 63 #fav
0x58 15 #app
0x18 65 #browser
0x0e 136 #audio
0x09 20 #subtitle
0x02 24 #info (osd)
0x01 30 #audio
key_end
Pachis
30 October 2021 22:16
6
Solved using this values instead of the ones I was using. Thanks.
system
Closed
30 January 2022 04:17
7
