Hello Everyone,
In another thread it mentions you can enable an disable the HDMI audio with these commands:
amixer sset 'Audio hdmi-out mute' on
OR
amixer sset 'Audio hdmi-out mute' off
Is there a way of testing if the status is ON or OFF?
TIA
Hello Everyone,
OR
TIA
Hello all,
N2 with CE 20.1.
I’m using Audio Profiles Add-on to switch between HDMI and SPDIF for the Audio. SPDIF is used for the Headphones so I still need the HDMI Video, but there’s still sound coming from the HDMI when using SPDIF.
Is there a way of turning OFF the HDMI Sound when SPDIF is selected?
TIA
amixer sget ...
Thank you that worked.
