I found following errors on external HDD (first partition, used as /storage. Second sda2 is fine)
[ 25.752220@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 1, block bitmap and bg descriptor inconsistent: 191 vs 190 free clusters
[ 25.833096@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 23, block bitmap and bg descriptor inconsistent: 7678 vs 1550 free clusters
[ 25.840086@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 24, block bitmap and bg descriptor inconsistent: 7678 vs 1666 free clusters
[ 25.848089@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 26, block bitmap and bg descriptor inconsistent: 7678 vs 7630 free clusters
[ 25.848099@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 27, block bitmap and bg descriptor inconsistent: 7661 vs 5525 free clusters
[ 25.854963@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 28, block bitmap and bg descriptor inconsistent: 7678 vs 1990 free clusters
[ 25.863093@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 30, block bitmap and bg descriptor inconsistent: 7678 vs 5590 free clusters
[ 25.863103@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 31, block bitmap and bg descriptor inconsistent: 7678 vs 5350 free clusters
[ 25.869970@2] EXT4-fs error (device sda1): ext4_mb_generate_buddy:756: group 32, block bitmap and bg descriptor inconsistent: 7678 vs 6718 free clusters
Is there a way how to trigger disc check and repair during next startup? This is remote installation, unfortunatelly I cant fix this in person this week
I know there is normal message
EXT4-fs (sda2): warning: maximal mount count reached, running e2fsck is recommended
which doesnt triggers full scan (and thats good), and there should be automatic trigger of disc repair when serious damage is done, but for this case
EXT4-fs (sda1): warning: mounting fs with errors, running e2fsck is recommended
its not triggered. Does I have any option to trigger one-time check and repair remotelly? Obviously I must run it after boot, as /storage is mounted…
/dev/loop0: TYPE="squashfs"
/dev/mmcblk0: PTUUID="0098b697" PTTYPE="dos"
/dev/mmcblk0p1: SEC_TYPE="msdos" LABEL="COREELEC" UUID="3001-0354" TYPE="vfat" PARTUUID="0098b697-01"
/dev/mmcblk0p2: LABEL="SD_DATA" UUID="1568868e-1619-47ff-820b-99abe9c45408" TYPE="ext4" PARTUUID="0098b697-02"
/dev/sda1: LABEL="STORAGE" UUID="7abb6ff0-d224-d401-40b2-6df0d224d401" TYPE="ext4" PARTUUID="16f2a91f-01"
/dev/sda2: LABEL="disk" UUID="b6ffbff8-d224-d401-00fe-bdf8d224d401" TYPE="ext4" PARTUUID="16f2a91f-02"
Thanks in advance
