JPS
21
Not working yet, I cant connect and get errors:
https://pastebin.com/raw/bvMMdhs2
As an alternative: Milhouse tries another way like your initial idea https://forum.libreelec.tv/thread/12789-adding-own-certs-to-connect-via-webdavs-sftp-again/?postID=95701#post95701, I will also test this and report here. I absolutely dont know what is better/more secure, but maybe CE can use that if it works.
We pull all changes from LE so whatever ends up there will also eventually make its way into CE.
JPS
23
Post a comment on the Github page and let the LE developers know.
Is the latest fix for self signed certificates included in CE .5 ?
If so, what do i do to make it work again?
I got the ca-certificates.crt file from the host server.
Thanks for all your hard work!
Yes it is, you have to store your pem file in /storage/.config/cacert.pem
edit.
All working good now. I can once again connect to my remote server
Thank you again for all your hard work and support. !
