HTTPS/FTP not working
Hello.
I have a server and use network stream through https and ftp to stream files.
Ever since CoreELEC 8.90.2 this does not work anymore.
When i downgrade to 8.90.1 everything works perfect.
Tried the newest 8.90.3 now and the problem is still there. Cant connect to already saved network locations.
I am on a wired connection and have tried fresh install with both sdcard and reset in settings.
Please help. I would like to upgrade to newest version :slight_smile:
No logs, no help. We don’t have a crystal ball.
Just wondered if there was a common error since nothing has changed on my end
Here is the error when i try to connect to the https server after upgrading to CE.3 or CE.2
Tried two separate boxes with same result (S905 and S905X)
ERROR: CCurlFile::Open failed with code 0 for https://USERNAME:PASSWORD@xxx.xxx.xxx.xxx:443/xxx/:
ERROR: GetDirectory - Unable to get http directory (https://USERNAME:PASSWORD@xxx.xxx.xxx.xxx:443/xxx/)
ERROR: GetDirectory - Error getting hxxps://USERNAME:PASSWORD@xxx.xxx.xxx.xxx:443/xxx/
ERROR: CGUIMediaWindow::GetDirectory(ERROR:
ERROR: CGUIMediaWindow::GetDirectory(hxxps://USERNAME:PASSWORD@xxx.xxx.xxx.xxx:443/xxx/) failed
Cant make much of it.
prodive full debug log, i have a clue.
Log
01:00:13.387 T:4090885712 NOTICE: special://profile/ is mapped to: special://masterprofile/
01:00:13.387 T:4090885712 NOTICE: -----------------------------------------------------------------------
01:00:13.387 T:4090885712 NOTICE: Starting Kodi (18.0-ALPHA2 Git:87ca87c). Platform: Linux ARM 32-bit
01:00:13.387 T:4090885712 NOTICE: Using Release Kodi x32 build
01:00:13.387 T:4090885712 NOTICE: Kodi compiled Jun 8 2018 by GCC 8.1.0 for Linux ARM 32-bit version 3.14.29 (200221)
01:00:13.387 T:4090885712 NOTICE: Running on CoreELEC (official): 8.90.3 (9.0), kernel: Linux ARM 64-bit version 3.14.29 aarch64
01:00:13.389 T:4090885712 NOTICE: FFmpeg version/source: 4.0-Kodi
01:00:13.389 T:4090885712 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
01:00:13.389 T:4090885712 NOTICE: ARM Features: Neon enabled
01:00:13.389 T:4090885712 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
01:00:13.389 T:4090885712 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
01:00:13.389 T:4090885712 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
01:00:13.389 T:4090885712 NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
01:00:13.389 T:4090885712 NOTICE: special://envhome/ is mapped to: /storage
01:00:13.389 T:4090885712 NOTICE: special://home/ is mapped to: /storage/.kodi
01:00:13.389 T:4090885712 NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
01:00:13.389 T:4090885712 NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
01:00:13.389 T:4090885712 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
01:00:13.389 T:4090885712 NOTICE: Local hostname: CoreELEC
01:00:13.389 T:4090885712 NOTICE: Log File is located: /storage/.kodi/temp//kodi.log
01:00:13.389 T:4090885712 NOTICE: -----------------------------------------------------------------------
01:00:13.400 T:4090885712 NOTICE: load settings…
01:00:13.401 T:4090885712 NOTICE: AML device detected
01:00:13.430 T:4090885712 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
01:00:13.457 T:4090885712 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/linux.xml
01:00:13.460 T:4090885712 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/amlogic.xml
01:00:13.462 T:4090885712 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/appliance.xml
01:00:13.464 T:4090885712 DEBUG: SECTION:LoadDLL(libbluray.so.2)
01:00:13.466 T:4090885712 DEBUG: Loading: libbluray.so.2
01:00:13.521 T:4090885712 DEBUG: CSkinSettings: no tag found
01:00:13.549 T:4090885712 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
01:00:13.549 T:4090885712 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="utf-8" ?>
false
1
30
cputemp
gputemp
0
01:00:13.549 T:4090885712 WARNING: CSettingsManager: missing version attribute
01:00:13.551 T:4090885712 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
01:00:13.551 T:4090885712 NOTICE: Default Video Player: VideoPlayer
01:00:13.551 T:4090885712 NOTICE: Default Audio Player: paplayer
01:00:13.551 T:4090885712 NOTICE: Disabled debug logging due to GUI setting. Level 0.
01:00:13.551 T:4090885712 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
01:00:13.551 T:4090885712 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
01:00:13.686 T:4090885712 NOTICE: PulseAudio: Server found running - will try to use Pulse
01:00:13.741 T:4090885712 NOTICE: Running database version Addons27
01:00:13.808 T:4090885712 NOTICE: ADDON: driver.dvb.hauppauge v9.0.0 installed
01:00:13.808 T:4090885712 NOTICE: ADDON: repository.coreelec v9.0.0 installed
01:00:13.808 T:4090885712 NOTICE: ADDON: xbmc.json v9.2.1 installed
01:00:13.808 T:4090885712 NOTICE: ADDON: metadata.common.fanart.t v3.4.1 installed
01:00:13.808 T:4090885712 NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
01:00:13.808 T:4090885712 NOTICE: ADDON: script.smoothstreams v0.9.6 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: imagedecoder.raw v2.0.0.2 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: repository.xbmc.og v3.1.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: webinterface.default v2.4.4 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: peripheral.joystick v1.4.6.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.chardet v3.0.4 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: service.coreelec.settings v9.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.global.main v1.0.13 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: repository.kodinerds v6.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: driver.dvb.crazycat v9.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: game.controller.default v1.0.5 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.idna v2.6 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.41 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: service.url.downloader v2.0.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.urllib3 v1.22 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: metadata.themoviedb.og v5.1.3 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: xbmc.metadata v2.1.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: inputstream.rtmp v2.0.3.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.resource v1.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.pil v1.1.7 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: xbmc.gui v5.13.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.program.driverselect v0.1.6.100 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: os.openelec.t v9.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: inputstream.adaptive v2.2.20.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: service.subtitles.subscene v1.7.2 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: xbmc.core v0.1.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.requests v2.18.4.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: os.libreelec.t v9.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: script.module.certifi v2017.07.27.1 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
01:00:13.809 T:4090885712 NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: vfs.rar v2.0.3.2 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.instance.game v1.0.38 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.album.universal v2.7.3 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.instance.pvr v5.9.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: script.module.url.downloader v2.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.common.allmusic.cm v3.2.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.tvdb.cm v3.0.5 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.common.musicbrainz.og v2.1.2 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.local v1.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.7 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.common.themoviedb.og v3.1.6 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.artists.universal v4.1.1 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.common.theaudiodb.cm v1.9.1 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: metadata.common.imdb.cm v3.0.6 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: xbmc.python v2.25.0 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: xbmc.addon v17.9.702 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: repository.smoothstreams v2.0.8 installed
01:00:13.810 T:4090885712 NOTICE: ADDON: skin.estuary v2.0.9 installed
01:00:13.965 T:4090885712 ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
01:00:14.015 T:4068766576 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
01:00:14.016 T:4068766576 NOTICE: Found 2 Lists of Devices
01:00:14.017 T:4068766576 NOTICE: Enumerated ALSA devices:
01:00:14.017 T:4068766576 NOTICE: Device 1
01:00:14.017 T:4068766576 NOTICE: m_deviceName : default
01:00:14.017 T:4068766576 NOTICE: m_displayName : Default (AML-M8AUDIO Analog)
01:00:14.017 T:4068766576 NOTICE: m_displayNameExtra: PCM
01:00:14.017 T:4068766576 NOTICE: m_deviceType : AE_DEVTYPE_PCM
01:00:14.017 T:4068766576 NOTICE: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
01:00:14.017 T:4068766576 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
01:00:14.017 T:4068766576 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
01:00:14.017 T:4068766576 NOTICE: m_streamTypes : No passthrough capabilities
01:00:14.017 T:4068766576 NOTICE: Device 2
01:00:14.017 T:4068766576 NOTICE: m_deviceName : hdmi:CARD=AMLM8AUDIO,DEV=0
01:00:14.017 T:4068766576 NOTICE: m_displayName : AML-M8AUDIO
01:00:14.017 T:4068766576 NOTICE: m_displayNameExtra: HDMI
01:00:14.017 T:4068766576 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
01:00:14.017 T:4068766576 NOTICE: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
01:00:14.017 T:4068766576 NOTICE: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
01:00:14.017 T:4068766576 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
01:00:14.017 T:4068766576 NOTICE: Enumerated PULSE devices:
01:00:14.017 T:4068766576 NOTICE: m_deviceName : Default
01:00:14.017 T:4068766576 NOTICE: m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
01:00:14.017 T:4068766576 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
01:00:14.017 T:4068766576 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
01:00:14.077 T:4090885712 ERROR: GetString: error reading /storage/.kodi/userdata/disp_cap
01:00:14.077 T:4090885712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 60.000000 Hz
01:00:14.077 T:4090885712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 59.940060 Hz
01:00:14.077 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 60.000000 Hz
01:00:14.077 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 59.940060 Hz
01:00:14.077 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 60.000000 Hz
01:00:14.077 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 59.940060 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1280 x 720 for display 0 with 1280 x 720 @ 50.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080i @ 50.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 30.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 29.970030 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 50.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 25.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 24.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 1920 x 1080 @ 23.976025 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 30.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 29.970030 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 25.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 24.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 23.976025 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 4096 x 2160 @ 24.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 4096 x 2160 @ 23.976025 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 50.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 60.000000 Hz
01:00:14.078 T:4090885712 NOTICE: Found resolution 1920 x 1080 for display 0 with 3840 x 2160 @ 59.940060 Hz
01:00:14.078 T:4090885712 NOTICE: Found (1920x1080@60.000000) at 41, setting to RES_DESKTOP at 16
01:00:14.098 T:4090885712 NOTICE: Checking resolution 20
01:00:14.312 T:4090885712 NOTICE: GL_VENDOR = ARM
01:00:14.313 T:4090885712 NOTICE: GL_RENDERER = Mali-450 MP
01:00:14.313 T:4090885712 NOTICE: GL_VERSION = OpenGL ES 2.0
01:00:14.313 T:4090885712 NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
01:00:14.313 T:4090885712 NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer
01:00:15.392 T:3981439856 NOTICE: Running database version Addons27
01:00:15.410 T:3981439856 NOTICE: Running database version ViewModes6
01:00:15.414 T:3981439856 NOTICE: Running database version Textures13
01:00:15.422 T:3981439856 NOTICE: Running database version MyMusic70
01:00:15.434 T:3981439856 NOTICE: Running database version MyVideos110
01:00:15.438 T:3981439856 NOTICE: Running database version TV32
01:00:15.440 T:3981439856 NOTICE: Running database version Epg11
01:00:15.442 T:4090885712 NOTICE: start dvd mediatype detection
01:00:15.498 T:4090885712 NOTICE: load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.9)
01:00:16.102 T:4090885712 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
01:00:16.153 T:3970958192 ERROR: CCurlFile::Exists - Failed: Couldn’t connect to server(7) for hxxps://USERNAME:PASSWORD@x.x.x.x:443/xxx/x.x.x.x:443/xxx/xxx/folder.jpg
01:00:16.183 T:4090885712 NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
01:00:16.183 T:4090885712 NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
01:00:16.187 T:4090885712 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
01:00:16.188 T:4090885712 NOTICE: Loaded playercorefactory configuration
01:00:16.188 T:4090885712 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
01:00:16.188 T:4090885712 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
01:00:16.204 T:4090885712 NOTICE: initialize done
01:00:16.205 T:4090885712 NOTICE: Running the application…
01:00:16.210 T:3903816560 NOTICE: ES: Starting UDP Event server on port 9777
01:00:16.212 T:3903816560 NOTICE: UDP: Listening on port 9777 (ipv6 : true)
01:00:16.390 T:3945780080 NOTICE: Register - new cec device registered on cec->AOCEC: CEC Adapter (0000:0000)
16:21:01.806 T:3920601968 NOTICE: service.url.downloader: SERVICE: STARTED
16:25:24.697 T:3819983728 ERROR: GetDirectory - Error getting
16:25:24.836 T:4090885712 ERROR: Previous line repeats 6 times.
16:25:24.836 T:4090885712 ERROR: CCurlFile::FillBuffer - Failed: Peer certificate cannot be authenticated with given CA certificates(60)
16:25:24.836 T:4090885712 ERROR: CCurlFile::Open failed with code 0 for hxxps://USERNAME:PASSWORD@x.x.x.x:443/xxx/:
16:25:24.837 T:4090885712 ERROR: GetDirectory - Unable to get hxxp directory (hxxps://USERNAME:PASSWORD@x.x.x.x:443/xxx/xxx/)
16:25:24.837 T:4090885712 ERROR: GetDirectory - Error getting hxxps://USERNAME:PASSWORD@x.x.x.x:443/xxx/xxx/
16:25:24.840 T:4090885712 ERROR: CGUIMediaWindow::GetDirectory(hxxps://USERNAME:PASSWORD@x.x.x.x:443/xxx/x.x.x.x:443/xxx/xxx/) failed
Looks like there is a problem with the SSL certificate from whatever host you are pulling files from.
The certificate is self signed.
Did the authentication method change from 8.90.1 to 8.90.2 ?
The dedi setup has been the same ever since Open and LibreELEC and worked perfect ever up to CE .1
Yes, within Kodi.
In case of self signed certs you have now the option to ad “-verifypeer=false” to your source url to make it work again. I worked hard for it: SSL Certificates Issues
But some library problems still exist within this “-verifypeer=false”(, also some other but not related to this string)
I have added a patch that will allow you to store a self signed certificate in /storage/.kodi/userdata/cacert.pem and use it in Kodi but it will not be available until the next version.
Im looking forward to check this out and give feedback :slight_smile:
Sorry for this noob-question: I downloaded my cert from nas and its called “CA.cer”. Can I just copy&past the content therein:
“-----BEGIN CERTIFICATE-----
…dsfkljdsflj…
-----END CERTIFICATE-----”
to the cacert.pem-file in coreelec /storage/.kodi/userdata/cacert.pem or do I have to convert this .cer-file in another way?
You may have to convert it however it’s not difficult.
Maybe its not working. I copied my “cacert.pem”-file, which includes my own cert and wich is working so far with windows nightly, in /storage/.kodi/userdata, but I still geht the log:
16:06:23.538 T:4089595280 ERROR: CCurlFile::FillBuffer - Failed: Peer certificate cannot be authenticated with given CA certificates(60)
Do you know whats the problem?
I used https://computerbastler.ddns.net/CoreELEC-Odroid_C2.arm-9.0-devel-03.07.2018.img.gz from computerbastler, where its actually merged according to him
Did you convert it to pem format?
It was not neccessary, seems it has already been in pem-format. I took the original cacert.pem from windows build kodi\system\certs and edited it with notepad+ and copy&pasted the content from my own “CA.cer”-file just at the end of the file. And this is how it worked in windows nightly - I can connect without any trouble.
For CE-test I just copied this modified file, but this time of course into /storage/.kodi/userdata/ , but in CE I cannot connect and get the bad log.
Is there any mistake from my side?
Thanks for testing, if this is not working I will remove the patch.
I found the kodi-file on Odroid under /etc/ssl - is there another way to edit it? I cannot overwrit it in that location, whren try editing it like in windows.
I like the idea of just put it into /storage/.kodi/userdata/ Maybe somebody other can check this twice? Would be so easy to handle this new ssl-issue.
FYI Adding own certs to connect via webdavs/sftp again - Feature Requests - LibreELEC Forum
I asked in LE Forum and at least people can workaround via script which is explained in the link.
Try the following build here
You will be able to add your self signed CA to the end of the file /storage/.config/cacert.pem
The SSL certificate file is now writable without having to bind mount.
