Hyperion.ng doesn't start on NE?
Hey there,
I’m using a Dune HD Homatics Box R 4K Plus with CoreELEC 21.2-Omega-ne.
I installed Hyperion.ng, made a reboot but port 8090 isn’t shown in netstat
CoreELEC:~ # netstat -tlpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:3702            0.0.0.0:*               LISTEN      665/wsdd2
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1302/sshd -D [liste
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      1392/smbd
tcp        0      0 0.0.0.0:9090            0.0.0.0:*               LISTEN      1511/kodi.bin
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      1392/smbd
tcp        0      0 0.0.0.0:5355            0.0.0.0:*               LISTEN      665/wsdd2
tcp        0      0 0.0.0.0:45037           0.0.0.0:*               LISTEN      1385/rpc.statd
tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      1/systemd
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1511/kodi.bin
tcp        0      0 :::33393                :::*                    LISTEN      1385/rpc.statd
tcp        0      0 :::22                   :::*                    LISTEN      1302/sshd -D [liste
tcp        0      0 :::445                  :::*                    LISTEN      1392/smbd
tcp        0      0 :::9090                 :::*                    LISTEN      1511/kodi.bin
tcp        0      0 :::139                  :::*                    LISTEN      1392/smbd
tcp        0      0 :::111                  :::*                    LISTEN      1/systemd
tcp        0      0 :::8080                 :::*                    LISTEN      1511/kodi.bin
Do I miss something? I tested it also with a fresh NE install on another USB stick, but same problem.
I didn’t tested NG (yet)
No one can help or have an idea, whats wrong? I will try tomorrow
Nobody can post debug logs, nobody can help…
I have similar problem : https://discourse.coreelec.org/t/hyperion-ng-amlogic-improvements/5476/379
