hi, i bought a FT232RL and connected it to my odroid n2. It is recognized as i can see in dmesg:
[ 72.094701@3] usb 1-1.2: new full-speed USB device number 6 using xhci-hcd
[ 72.224383@3] usb 1-1.2: New USB device found, idVendor=0403, idProduct=6001
[ 72.224386@3] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 72.224388@3] usb 1-1.2: Product: FT232R USB UART
[ 72.224390@3] usb 1-1.2: Manufacturer: FTDI
[ 72.224392@3] usb 1-1.2: SerialNumber: AQ00RBVN
[ 72.226970@3] ftdi_sio 1-1.2:1.0: FTDI USB Serial Device converter detected
[ 72.227027@3] usb 1-1.2: Detected FT232RL
[ 72.230927@3] usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB1
is connected the led strip to it (green to green, yellow to yellow, rx/tx).
i can see that the usb controller is working (power led) and i see a rx tx led on it but it does not blink. so i guess something is wrong configured in hyperion. hyperion probably does not use that usb device to send the data.
in LED hardware i have:
controller type: file
rgb byte order: rgb
output path: /dev/ttyUSB1
anyone an idea what is wrong?
i have configured in effects that background effect should be knight rider and boot effect should be knight rider. but its always the rainbow effect which comes from the led stripe itself when powering on.
edit: just noticed that the first LEDs are blinking now. but not as expected. so i guess there is some kind of signal that is sent but not what i would expect. it is sk9822 LEDs. maybe someone can help me to configure hyperion?
