Hi, after buying a light kit I have installed it and configured hyperion, it happens that the lower part and part of the left side do not turn on, but when I reset, all the LEDs light up, someone knows what could be happening, thanks
Sounds like black boarder detection is turned off.
Please check your hyperion config. It’s easy to configure hyperion by the web interface it includes.
Some hyperion configuration tutorial, I used a configuration seen in a telegram channel but it is an older version and there are things that are not the same
black border detection is disabled, that where it is
