Image for Ugoos AM9 Pro missing CE 21.3
Hi, can someone help me with this. I want to install Coreelec 21.3 on my AM9 Pro, but when I go to download the image file, it says it does not exist. Please help!
Here is your answer.
Ok, I was confused because on the download helper page it does list the AM9 Pro under the new installation for 21.3, then this link comes up when I click “download image” button
https://github.com/CoreELEC/CoreELEC/releases/download/21.3-Omega/CoreELEC-Amlogic-no.aarch64-21.3-Omega-Generic.img.gz
From what I can tell:
  • Development on 21.3 (4.9 kernel) ended in Nov 2025.
  • AM9 Pro came out recently, well after 21.3 development ended. So it’s not supported and never will.
  • The only build in development that supports the AM9 Pro is the 5.15 kernel CE 22.0 nightlies. You can download them here: CoreELEC nightly builds .
