I want to buy this interesting Device!
Is there any problems with the specs to get running coreelec via usb port?
Do we have some remote configs?
It´s Google Certified.
bootloader probably locked
Do any Mag Device runs coreelec? I need the dual boot option…
I think this will do the job.
Can someone confirm, this will run coreelec?
Does the remote will work?
Streamers with low specs have the bootloader locked. Stop chasing wild and cheap dreams. Buy one unit and try to boot from USB port, if doesn’t work, send it back.
It’s impossible to confirm this without having a device physically available to run tests on.
for remotes, there is the Repository for AmRemote & Meson IR Remote Controllers
