I need plug-in *ipk to work in coreelec …can it happen ?
Amlogic s905d
What plugin you’re looking for buddy?
Let’s keep it simple
Every Add-on should contain the authors name, this is found by opening the Context menu on the Add-on and selecting Add-on Information
Generally a search of the Add-on’s name together with the author name will give the location of where the author is active.
blugin time shift
and translate english to any language
