Initial Install with Remote Control enabled?
I have an X96Air which had an older version of Coreelec installed on a micro SD
I just installed 20.01-Nexus which does seem to boot properly.
The issue is that the remote control can’t be found so i want to use my iPhone (which has the app installed already and was working on the old version).
I used to be able to install an empty file called ssh to enable ssh/remote control on first boot (this didn’t enable remote control, I don’t think). This doesn’t work (I can’t ssh in).
Is there a way to enable using the iPhone as a remote prior to the first boot? Help?
Andrew
You can’t use app. Connection needs to be set up in settings. Plug in some keyboard and set it all up :wink:
Thanks. My brain totally whiffed on the idea of attaching a keyboard. Duh!
