Hello, i have a Z69 (s905X/3GB-32GB) box, to which i have CoreElec installed and running. I’m using TVheadend for watching TV using a USB DTV tuner. The problem is that when i schedule a recording, and i’m putting the device to suspend (i have already changed ‘sleep.conf’), the device does not wake up to start the recording. I know that it has something to do with the bootloader, but i don’t know how to fix that. If i put my device on suspend, i am able to wake it up after a minute by remote, but sometimes, the DTV tuner is not working afterwards (maybe needs to restart its service after wake up, but i don’t know how to do that either). Could someone give me some help, or create a feature as BL301 inject for my bootloader? I would be glad to test any bootloader, to see if it works… Thank you in advance!
I am sorry, BL301 injection is only available for G12A/B, A311D and S905X2.
A support may be added later…
OK, i understand, but could you please give me an idea how to make, my bootloader wake up when i set a recording? I will try to figure it out…
