Input stream adaptive + Kodi Piers
By last builds of CE22NO are trouble with online streams which are played “ in cca 5 seconds loop”. Bug is present cca 2 week. These streams was tested at ce21NG and was normal played at identical device.
https://paste.coreelec.org/ActivateNineties
https://paste.coreelec.org/BraunTopside
https://paste.coreelec.org/BlurtMartha
https://paste.coreelec.org/MournTippin
Maybe input stream adaptive addon is not well working. Only is well working maybe for youtube addon, but are negativly affected pvr and other addons.
2025-11-13 19:55:07.571 T:1379  warning <inputstream.adaptive>: <<<<<<<<< DEPRECATION NOTICE >>>>>>>>>
                                                   DEPRECATED PROPERTIES HAS BEEN USED TO SET THE DRM CONFIGURATION.
                                                   THE FOLLOWING PROPERTIES WILL BE REMOVED FROM FUTURE KODI VERSIONS:
                                                   - inputstream.adaptive.license_type
                                                   - inputstream.adaptive.license_key
                                                   - inputstream.adaptive.license_data
                                                   - inputstream.adaptive.license_flags
                                                   - inputstream.adaptive.server_certificate
                                                   - inputstream.adaptive.pre_init_data
                                                   YOU SHOULD CONSIDER MIGRATING TO THE NEW PROPERTIES:
                                                   - inputstream.adaptive.drm_legacy
                                                   FOR MORE INFO, PLEASE READ THE WIKI PAGE: https://github.com/xbmc/inputstream.adaptive/wiki/Integration-DRM
https://paste.coreelec.org/WellesTotal
https://paste.coreelec.org/PupilsSurvivor
[  155.383014] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:4
[  155.383042] period_time:1000ms isr_sum_time:42ms, cnt:17584, last_exec_time:2us
[  157.041314] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:2
[  157.041334] period_time:1000ms isr_sum_time:23ms, cnt:37785, last_exec_time:0us
[  158.041315] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:1
[  158.041333] period_time:1000ms isr_sum_time:16ms, cnt:26977, last_exec_time:0us
[  161.229276] [hdmitx:] hdmitx_audio_notify_callback[798] audio prepare
[  161.229349] frddrs[0] released by device ff642000.audiobus:spdif
[  164.909573] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:7
[  164.909595] period_time:1000ms isr_sum_time:75ms, cnt:122068, last_exec_time:0us
[  182.288895] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:6
[  182.288914] period_time:1000ms isr_sum_time:63ms, cnt:103417, last_exec_time:0us
[  195.381308] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:5
[  195.381328] period_time:1000ms isr_sum_time:50ms, cnt:82029, last_exec_time:0us
[  206.443889] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:5
[  206.443905] period_time:1000ms isr_sum_time:54ms, cnt:87462, last_exec_time:0us
Updating of widewine cdm solved “Integration-DRM" and “IRQRatio___ERR.irq” i dont see now.
But always is issue with looping my streams in PVR (in CE21NG are these streams ok). Youtube and Netflix are ok on both system 21ng and 22no.
So here are logs from last build. Always are loops in tv streams. SimpleIPTV was used in test. These stream services with input stream 21.5.17.1 are ok in CE21NG.
2025-11-15 05:38:34.917 T:1406    error <general>: static bool CInputStreamAddon::Supports(const ADDON::AddonInfoPtr&, const CFileItem&): 'inputstreamaddon' has been deprecated, please use `#KODIPROP:inputstream=inputstream.adaptive` instead
https://paste.coreelec.org/PedalManager
https://paste.coreelec.org/DeaverSeein
https://paste.coreelec.org/StampCrates
Streams are from freeview:
2025-11-15 05:38:30.266 T:1369    error <general>: /storage/.kodi/addons/plugin.video.freeview.sk/main.py:103: SyntaxWarning: invalid escape sequence '\d'
                                                     psettings = [settingToListItem(os.path.join(pprofile,f)) for f in ppfiles if re.search("^instance-settings-\d+.xml$", f)] #TODO os.path.isfile?
Also paid stream service Antik have issue - is stoped after some 30 seconds:
2025-11-15 05:38:30.678 T:1332    error <general>: /storage/.kodi/addons/plugin.video.antik/service.py:11: DeprecationWarning: datetime.datetime.utcnow() is deprecated and scheduled for removal in a future version. Use timezone-aware objects to represent datetimes in UTC: datetime.datetime.now(datetime.UTC).
                                                     tz_offset = int((time.mktime(datetime.now().timetuple())-time.mktime(datetime.utcnow().timetuple()))/3600)
[  645.816373] period_time:1000ms isr_sum_time:77ms, cnt:128068, last_exec_time:0us
[  647.816357] IRQRatio___ERR.irq:2/IPI action=ipi_handler ratio:8
https://paste.coreelec.org/PlotsBucket
I feel that is not issue of coreelec but third addons which not reflected changes in inputstream.adaptive addon.
Few days ago downgrading to Input stream adaptative 21.5.9 would bypass the issue.
But you would prefer to update to ISA 21.5.17.1 that will solve this issue👍
I have always without “pause“ from october this issue with streams, and also at last input streamer adaptive 22.3.2.1. (i dont see possibility for installing of alternative versions to CE22NO or i dont have idea that how).
2025-11-27 19:56:10.891 T:1420    error <general>: static bool CInputStreamAddon::Supports(const ADDON::AddonInfoPtr&, const CFileItem&): 'inputstreamaddon' has been deprecated, please use `#KODIPROP:inputstream=inputstream.adaptive` instead
https://paste.coreelec.org/SombreroHints
https://paste.coreelec.org/PsychicCeltics
https://paste.coreelec.org/PfeifferDiesel
Trouble are with some streams in loop. This bug is only in CE22NO. CE21NG is ok with identical streams.
After that 3 minutes of playing is stoped looping and stream play correct. Identical behaviour is with last build from 29.11.2025. Issue with buffer ?
I think it’s better to search and ask for help there:
We just build the binary - nothing else.
2025-11-15 05:28:23.066 T:1353     info <general>: Creating PVR client: addonId=pvr.nextpvr, instanceId=1, clientId=2
2025-11-15 05:28:23.072 T:1353     info <pvr.nextpvr>: Creating NextPVR PVR-Client
2025-11-15 05:28:28.322 T:1353    error <general>: CCurlFile::CReadState::FillBuffer - (0x7f483f20c0) Failed: Could not connect to server(7)
2025-11-15 05:28:28.322 T:1353    error <general>: CCurlFile::Open - <http://127.0.0.1:8866/service?method=recording.lastupdated> Failed with code 0:
2025-11-15 05:28:28.322 T:1353     info <pvr.nextpvr>: No running server found expect a failed install
2025-11-15 05:28:29.038 T:1353     info <pvr.nextpvr>: Buffer created!
2025-11-15 05:28:29.039 T:1353     info <pvr.nextpvr>: DummyBuffer created!
2025-11-15 05:28:29.039 T:1353     info <pvr.nextpvr>: Buffer created!
2025-11-15 05:28:29.041 T:1353    error <general>: CCurlFile::CReadState::FillBuffer - (0x7f48242910) Failed: Could not connect to server(7)
2025-11-15 05:28:29.041 T:1353    error <general>: CCurlFile::Open - <http://127.0.0.1:8866/service?method=session.initiate&ver=1.0&device=xbmc> Failed with code 0:
2025-11-15 05:28:29.041 T:1353    error <general>: ADDON_STATUS ADDON::IAddonInstanceHandler::CreateInstance(): pvr.nextpvr returned bad status "Permanent failure" during instance creation
2025-11-15 05:28:29.041 T:1353    error <general>: ADDON_STATUS PVR::CPVRClient::Create(): Failed to create PVR add-on instance 2. status=5
2025-11-15 05:28:30.153 T:1314     info <general>: Loading skin file: DialogAddonSettings.xml, load type: KEEP_IN_MEMORY
ok
Same with PVR addons:
I think this is self explained?
In CE21ng is going identical stream without issue (i use CE21NG now due to this problem at CE22NO. Before cca 15.10.2025 was not problem with these streams also in CE22NO).
Then report this please to the add-on author.
We can’t do anything.
You can not compare CE-21 to CE-22 version as the old version is not maintained anymore for a while. Not from the author, not from platform.
Issue is checked.
In this case (these streams only at CE22NO) the video is playing near the live edge
and caused some kind of abnormality.
Maybe is fixed in version of inputstream.adaptive addon from today.
Bug is really fixed. We must wait at next new version of addon.
There was today officialy realised new version of addon:
Do you have issues with video steam freeze on CE22-20251207+IPTV simple and ISA addon?
Videoplay (live tv stream) starts good with 100% video cache but after some short time video cache goes from 100% to 0% and video stream freezes.
Same mpd/m3u8 works without issus on OSX latest nightly Kodi 22
You must have updated widevine with newer ISA. I dont have issue with Netflix and IPTV.
Ok, now i know addon Antik, which is ok at windows version of Kodi 22, but not at Coreelec. Author of addon said that is crashed at system failure and not at addon failure. Bug is also at last build and have identical symptons: cache at 100% and after 20nseconds is at 0% and video is stopped.
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/iptvsc.py”, line 12, in
from resources.lib.channels import Channels
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/channels.py”, line 17, in
from resources.lib.settings import Settings
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/settings.py”, line 10, in
from resources.lib.session import Session
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/session.py”, line 9, in
from resources.lib.api import API
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/api.py”, line 6, in
from resources.lib.utils import ua, get_api_url
File “/storage/.kodi/addons/plugin.video.antik/resources/lib/utils.py”, line 11, in
addon = xbmcaddon.Addon()
RuntimeError: Unknown addon id ‘plugin.video.antik’.
–>End of Python script error report<–
These stream are not free. Try you share here your touched streams if are free.
