Inputstream.adaptive not compatible with CoreELEC 21 after upgrade
I’m running CE 21.2 after updating from CE 19.5 on my N2+. But now the inputstream.adaptive, RTMP Input, Inputstream FFMpeg Direct,TVHeadend HTSP Client and PVR IPTV Simple Client addons are not compatible! Is thre a way to get them working under CE 21.2 on my N2+?
Thanks!
Uninstall them and install again?
There is no other version offered.
Select CoreELEC addons repository and from context menu select refresh.
Ok., I made a mistake with the CE Versions. I’m only able to upgrade to CE 20.5, when I try to upgrade to 21.2. nothing happens! WTF? Your way to activate the addons worked fine under 20.5, thanks for that. But how can I upgrade to CE21.2? After confirming the upgrade to 21.2 the popup disappears and nothing will be loaded…
Manually?
https://wiki.coreelec.org/coreelec:updates
I tried manual. CE 21.2 is shown twice and I tried both of them, but got no success.
Your description is very vague: you need to be much more clear.
And it is normally better to make clean installs between major versions anyway.
Tried manual from CoreElec settings, unfortunately this don’t works. Now I’ve chosen the USB-drive method and erverything is fine! Many thanks to you!
I hope that all this wil be a bit more easier in the future or a complete user-manual for updating OS and all addons.
Nothing will change because everything works fine.
With manual update I meant using .tar file putting into update folder.
